So I've downloaded a livestream in realtime using N_m3u8DL-RE.
After the stream ended, N_m3u8DL-RE did not merge the downloaded ts files into one single file. So now I only got a whole list of ts files and I want to merge them into a single ts/mp4.
I tried the following command using ffmpeg:
And when I executed the concat command, ffmpeg gives the following error many times:Code:Create filelist txt file: (for %i in (*.ts) do @echo file '%i') > mylist.txt Concat all ts files into output.ts: ffmpeg -f concat -i mylist.txt -c copy output.ts
The resulting output.ts file successfully merged all the TS segments, but the audio stutters approximately every 20 seconds and appears to have some sync issues.Code:start time for stream 0 is not set in estimate_timings_from_pts
How should I merge the TS files in this case? I've looked at the documentation for N_m3u8DL-RE, but there doesn't seem to be an option to merge files that have already been downloaded.
Below are the video info for the first two TS segments for reference:
Code:General ID : 1 (0x1) Format : MPEG-TS File size : 6.96 GiB Duration : 2 h 52 min Overall bit rate mode : Variable Overall bit rate : 5 760 kb/s Frame rate : 25.000 FPS Video ID : 256 (0x100) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L5 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference : 4 frames Format settings, GOP : M=1, N=15 Codec ID : 27 Duration : 2 h 52 min Bit rate mode : Variable Maximum bit rate : 5 500 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Time code of first frame : 02:04:37:20 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 257 (0x101) Menu ID : 1 (0x1) Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Format version : Version 4 Muxing mode : ADTS Codec ID : 15-2 Duration : 2 h 52 min Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : -29 msCode:General ID : 1 (0x1) Format : MPEG-TS File size : 6.95 GiB Duration : 2 h 52 min Overall bit rate mode : Variable Overall bit rate : 5 760 kb/s Frame rate : 25.000 FPS Video ID : 256 (0x100) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L5 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference : 4 frames Format settings, GOP : M=1, N=15 Codec ID : 27 Duration : 2 h 52 min Bit rate mode : Variable Maximum bit rate : 5 500 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Time code of first frame : 02:04:41:10 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 257 (0x101) Menu ID : 1 (0x1) Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Format version : Version 4 Muxing mode : ADTS Codec ID : 15-2 Duration : 2 h 52 min Bit rate mode : Variable Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : 19 ms
Results 1 to 1 of 1
Convert a Single PNG into a Five-Second MP4, Preferably via FFmpeg
By raywood in forum Video ConversionReplies: 4Last Post: 8th Jul 2024, 14:44 -
ffmpeg join files from bat
By whs912km in forum Video ConversionReplies: 2Last Post: 16th Apr 2024, 06:27 -
Best free way to split or join .MP4 files?
By Nagashi in forum EditingReplies: 31Last Post: 16th Nov 2023, 00:16 -
Right way to join two different video files using ffmpeg?
By yetanotherlogin in forum EditingReplies: 15Last Post: 25th Jun 2021, 03:25 -
How to join mp4 files , when there encoding settings are different ?
By zyck in forum Video ConversionReplies: 8Last Post: 19th Jun 2020, 05:41
